which 1 do i cut?
hadz
286
West Sussex
right i have been out and its still only just hittin 5PSi sumtimes only 4! do u think i have got a boost leak?
also for sum reason my Oil Temp gauge keeps misting up, and i cant work out why! any1 got any idea or had the smae problem?
LeeroyBrown
Rite on!!!
May 7, 2005
359
Cornwall
gazjones said:
thrashing it dosent give you full boost if i thrash mine i get around 16 psi but putting my foot down in 5th from 20 mph up through rev range i hit 20psi try loading and letting turbo spool up on full throttle that give max boost
Thrashing it in mine i hit over 20psi easy everytime, if i boot it in 2nd i got 22psi, and when i put my foot down in 5th from low i hit 26.. Surly you should be hitting more than 16psi? When i had stage one i was hitting 20psi easily in 2nd upwards..:shrug:
gazjones
ci dont know im running it off the top of the dump valve with an auto gage boost and vag gauge its at around -20 to 30 most of the time then goes up to around 20 psi max
gazjones
its on standard revo setting on stage one not sure if boost is that high or could be cranked up a bit
wazo
293
lincoln
this is mine now ive removed all that n249 valve all boost is direct now from inlet manifold and boost gauge direcly t`d into top of dv boosts right up to 20 psi
hadz
286
West Sussex
LEEROY yeah i have got the double nomad pillar mount thing! y does that matter?? at standard i should be gettin more than 5 shouldnt i?
-pseudonymous-
681
Hadz do you have vagcom? Ideally you could do with doing some data logging on the delivered boost in block 115. I dont think 5psi is overly low for a standard cupra but somebody may correct me. Also its possible intake temperatures may be a factor but unlikely on a non-remapped car.
Lee is your car running ok now then, i remember reading somewhere u had problems after fitting the K03s...
-pseudonymous-
681
I thought the 'R' hit nearer 10 psi and the Cupra peaked at 5-6psi? Been that long since i ran standard boost i dont remember lol
Make sure all your vac pipes and the pipes to and from the intercooler are tight. I would replace the vac piping for silicone ones anyway if you havent already done so. Also what dump valve have you got fitted?
Ollie.
hadz
286
West Sussex
i havent got vagcom and to be honest i dont really know what it is! i thought that 5 was rather low but if thats what other people get ona standard cupra then im not to worried! what is block 115?
hadz
286
West Sussex
i have got a forge dv! im going to replace them all but where is the best place to by the silicone hosing from? is the stuff on ebay alright? also what thickness do i need?
-pseudonymous-
681
How long has the Forge DV been fitted? Maybe it needs servicing. Also just out of interest what colour spring is in the valve?
You will need 3-4mm vac pipe, try forge motorsport or ebay like you said.
LeeroyBrown
Rite on!!!
May 7, 2005
359
Cornwall
because i have double piller mount and my top gauge (oil) mists up aswell, have u got an autometer gauge aswell?? Its because they r not sealed units and if u have the heaters on and the window open its mists up very annoyin i know..
hadz
286
West Sussex
i have stewart warner gauges and mine keeps misting up! its proper annoying isnt it! i thought it was me or i have a faulty gauge! is there anyway of stopping it? i wonder y it is only the top gauge that does it?
LeeroyBrown
Rite on!!!
May 7, 2005
359
Cornwall
because the bottom gauge is gettin loads of heat or air from behind the gauge, and the top one doesnt get that i guess?? I even sent a gauge back because i thought it was faulty but the next one happened again.. :lol:
hadz
286
West Sussex
u got any idea how you can stop the top gauge steaming up?
also which is better 3mm or 4mm for the vacum hose?
