Window and door mirror switch illumination - not.
iain1970
I ♥ TDI
Apr 19, 2005
484
The Wrong side of the Pennines
As the clocks go back, little faults are found ;)
None of the four window switches in the drivers door illuminate, nor does the door mirror control. Not life threatening, but a bit annoying.
What do I need to do to get the bulbs replaced without destroying things? I've read about door cards being a bugger to remove, so I hope I can avoid that.
iain1970
I ♥ TDI
Apr 19, 2005
484
No idea, although I've not a clue where the fuse box is!
They have illuminated fine the last two nights. Oddly, the rear window lock switch illuminated and changed colour OK when the four window switches didn't.
Odd.
kenjo1957
Window switch illumination
I too have the same problem and also the air con display doesn't appear to light up. Any ideas please?
