Winter is here.
ayrshiredude
208
23
So winter seems to have hit with vengence up here in Scotland. Its been very wet the past few weeks. So I am back to my windscreen fogging up anytime it's raining. I have tried cleaning the windscreen (using a magic eraser sponge then drying it off and finishing with microfibre cloth) then used Rain X anti-fog but its still fogging up whenever its raining. Its basically at the point where I have to have the aircon set to windscreen to keep it clear. If I set it back to front vents to warm the cabin the windscreen fogs up again.
Don't remember a car as bad as this. Any suggestions?
Jonathan Bassett
124
30
I find a 100% clean windscreen, and then the cars climate control set to auto and at 20° it stays clear while its raining. That’s after the initial fogging it does from cold.
ayrshiredude
208
23
Unfortunately I only have manual air con so its either I keep the windscreen clear or I keep me warm. I'm not sure if this is normal or there is a leak somewhere
Jonathan Bassett
124
30
It could be, if it is fogging up nearly all the time it could be a cause of water ingress as there’s moisture in the cars interior... can’t be anything too serious though, as usually you’ll be able to feel water in the foot wells, and/or water in the boot, where the spare wheel is housed.
camelspyyder
2 SEAT-er
Jun 26, 2014
1,305
175
Can you not set the distribution between both screen and face positions and split the warm air?
The rotary controller is not digital.
