I've had a quick look for the answer to this but as yet not found one. I have a 2000 Toledo TDI and recently the wipers have started to play up. If I switch them to intermittent or speed one or even try the washers the wipers will not work. It I switch them to fast they work, if I switch them to fast and then back to intermittent, speed one or wash then they work again, for a while.
Is this likely to be a switch problem, relay or the motor itself.
Can't believe that I am the first person to experience this so turning to you guys for some advice before I start going buying loads of different bits,
Thanks in advance
Thanks in advance
