Wiring To Fuse Box
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
How easy is it to connect a wire to the fuse box in these cars and the best way to do it??
I have a gauge to wire in and there are 6 wires and one will be for the fuse box/permanent power.
And where is the nearest earth around that area?
Thank,
Craig.
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
what your after is a permanent live and a ground? easiest for live is off the back of the headunit! and ground just strap it to the head unit ground.
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
^^ as he said
all the wiring you could need including ignition and permanent lives and if you are doing a pillar gauge then 2 screws for the speedo surround to run the wires across and back of the light switch for illumination
CraigW
Craig.
Apr 12, 2007
4,607
Yep that would probably be the easiest way but I want to try and keep all the wires from the pillar gauge all across that side of the car if at all possible.
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
back of the headlight switch then for a perm live from the sidelight supply but you'll need a multimeter to confirm which one though as i can't remember
you'll have illumination supply too of course
and while switch is out there is a couple decent earth mounting bolts just inside from memory + 1 on switch anyway
