Would it be wise to get a cambelt change
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
just set the cams and crank to TDC these are marked. to make sure crank is set remove spark plug 1 and put a screw driver in the cylinder, watch it rise when it stops before it goes down this is TDC. there will also be a mark on the flywheel.
with those set remove the Dizzy cap, there is a line/mark for TDC of the dizzy, your engine is now static timed.
vngtx
did that but its still in limp mode? i can take it out with vagcom and it revs beautifully to 6.5k . it has me baffled.
TiggsGTI
Rust is fashionable...
Jun 10, 2010
721
Stirling
www.facebook.com
i reckon that noise is actually the brake discs. but can never be sure.
I hope not! I just got new discs and pads all round and 2 rear wheel bearings. My noise only happens on idle, and when its heated up. My mechanic is in hospital too need to find a non cowboy to take it too. I heard it was about £200 to replace a timing belt :blink:
I am going to order one from euro car parts its about £70 for the kit for the 16v.
Mat Lock
Carless Wonder
May 24, 2007
626
Purley, Surrey
www.mat-lock.net
That sounds like what I have.
I dont hear it when i first drive the car. Only after about 10 mins use. Pull up at lights, open window and can hear it shiffling away ccchf ccchf ccchf ccchf
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
mines only noisey on idle after 5 minutes it goes completely just annoying. best thing to do is first remove the power steering belt. if it doesnt make the noise its the power steering pump.
then remove the alternator drive belt, if it stops it could be anything driven from that including the tensioner. mine just sounds from within the timing cover.
vngtx
i still have it even with all 3 belts changed. could be power steering pump. ive had new water pump on so cant imagine it being that. or alternator.
Mat Lock
Carless Wonder
May 24, 2007
626
Purley, Surrey
www.mat-lock.net
You're talking to someone who describes noises as cccchf lol I have no idea about the underneath of my car haha
Probably why I've always paid so much for repairs cos I have no idea what they're telling me.
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
mine is the water pump, bearings noisey. £22 for a new pump so not too bad.
my cambelt was changed 7k ago so ill leave that :)
chipmunk82
MK3 Ibiza Cupra
Aug 26, 2010
119
Stroud
Can someone just confirm cambelt change interval for me?
Is it 60k or 5 years whichever comes first?
On the 16v should you do the waterpump at the same time
