Would you buy a car with the EML on?
Karnus
Looking at a car with a intermittent EML light problem undiagnosed - would you touch it?
Sent from my GT-I9300 using Tapatalk 2
Karnus
When you say plug it in...?
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
Yes I would. I would use it as a tool to drive the price down after I plugged my VCDS in whilst on a test drive (out of sight of the seller) and found out what the fault was.
Do some reading up on VCDS or VAG-COM (same thing)
Karnus
Would I get codes back or something I would understand?
Edit: checked it out and looks awesome but also expensive, and it would be difficult to diagnose without the seller being there
Nath.
Jan 1, 2006
8,620
16
Yes, the official VCDS is very expensive but you can get a rip off copy for about £30.
As long as you keep the internet off whilst using it, it's exactly the same.
Seal_LCR
2,601
Redditch
I'd only buy like above said I'd read the code. It might be something simple then I'd drive the price down. If he isn't willing to let you plug it in walk away or if you haven't got the facility to plug in walk away
beastgtir
298
Sounds dodgy if its intermittent,
I bought mine with the EML on, was told it was decat.
Drove it for a while and didn't bother checking it.
Finally got it on a cheapy scanner and indeed was the decat - it was reset and i've ordered an 02 sensor spacer.
Should be end of it..
But the thing with an engine light - it could be more then just one issue!!
Seal_LCR
2,601
Redditch
Could e a simple thing like a cool pack going though that's an intermittent EML
beastgtir
298
It all depends on the price.
Is it cheap enough to gamble and do you have the experience to repair If needed.
Seal_LCR
2,601
Redditch
Exactly it!
If you know what the problem is and it's a quick fix keep it shut and haggle of your not sure or it could be a number of things knock the price to allow for these things if not walk!
Karnus
Sold straight away - he who hesitates is lost. Never mind.... Next time!
