crossedmike
if an abf was to be turboed would the ecu need to be swapped to a mega squirt or after market one or could it just be mapped i wondered this
new ecu... theres nothing in an ABF ecu to read or regulate boost
wouldnt go with mega squirt tho...
try get a second hand ecu thats a better known make.
They all use 'standard sensors' to input to the ecu... mega squirt wouldnt me my personal choice
Yep even if you want to run your NOS correctly the standard ECU isn't ideal!
I've DTA S40 Pro I think.... I've seen a lot of people using megasquirt on Club GTi, all depends on your budget! And trying to find a mapper that likes megasquirt!
Best way to decided is find somewhere you want to take you car to be mapped and ask what make of engine management they prefer to use.
DTA, Omex or Emerald will all be suitable for what you want. A cheaper option is megasquirt. Have a look on clubgti, for a price toyotec on there will build you a megasquirt setup and sort you a base map. He has turbo'd his own abf as well.
There are ways to chip the standard ecu to allow boost to be used, but the cost of it will be more than buying a standalone.
yep read that before
always the case, have a look at "powernut" on here, he does the same
na he has a 4wd mk1 caddy, running a vr6 turbo (450+bhp) he fabricates everything himself
