Mine was dumping on full boost this weekend occasionally so I will be servicing the DV and installing a yellow spring.
21psi on a stage 1 map? - Not likely...
Depends on the map. Mine goes to 23.5psi in 4th, Revo stage 1.
EDIT - actually also depends on car/turbo. Kriso has a 225 LCR, you have an LC so maybe stage 1 on a LC doesn't go that high.
Makes sense ... didnt realise the convo was about the 'R' version ...
It wasn't, sorry - I posted before to say 21psi is pretty normal for a stage one then realised that you and Kriso have different cars so was just explaining how I'd got confused
PMSL... NOW I'm confused... ... what were we talking about?
Awesome recommend yellow spring for remapped cars apparently.
I'm dumbfounded a stage 1 map peaks at 1.58 bar or 23 psi in 4th!!!!! Either that's powerful or mine is seriously under power.
Mine has 281 bhp but I peak at 1.35 bar and hold 1.28 ish.????
Sent from my iPhone when I should be working....
lol, but i need boost in my life ;-)
Yeah i realise you dont always need big boost to get high power, but im unsure how i got my current figure on a boost curve like that? I apologise if we are going off topic but in 4th mine holds 1.35 is all the way virtually through the rev range.....you say its 'Revo's thing' but the linear map was to corect the high peak readings...no?
