Zeitronix wiring help
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
pulled off the net: (disclaimer)
ZT2 Pin # for EVO 9
1 (red) – I tapped this into ECU pin # 47 wire (Battery)
2 (white) – don't use
3 (green) - wired this to ECU pin # 45 wire (tachometer)
4 (orange) – wired this to the Green Boost sensor wire
5 (white / blue) – not used yet, but I will wire the Alarm /
Light later
6 (yellow) – wired this to the Red Boost sensor wire
7 (Black) -- ECU pin # 46 wire (sensor earth)
8 (Sensor Ground) -- ECU pin # 49 wire (power ground)
9 – not used
10 (grey) -- ECU pin # 78 wire (TPS)
11 (brown) – wired this to the Black Boost sensor wire
12 – not used
MORE USEFULL pdf from zeitrnoix tho... magic of google chap ;)
http://www.zeitronix.com/installation/ZT2instructions.pdf
minimivic
Drives a 16v mini
Aug 26, 2006
189
Dorset
www.btinternet.com
Bill,
Same info as i found, google is a good friend of mine too. What I was after was the ECU pin outs or colours for the ME7 to save me some time working it all out.
Thanks anyway,
BTW is the rolling road in yet?And can you do alignment?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
you did not mention ecu pin outs is what you were asking for :rolleyes:
RR is not in no.. wish it was.. so I really wish it was.
Premesis move is next thing to happen. I wont be installing the dyno where I am, so the move dictates the dyno install. It cant happen soon enough as far as I am concerned, but at this time I am still negotiating the premesis and floor plans with agents. wish it was going faster.. frustrating the hell out of me currently.
soon tho.. weeks not months.
2wheel alignment yes I can do, 4wheel I take the cars to Chris Mullins in Glos and use their 4wheel equipment to adjust
