Strut Brace
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
it should be on their system as a inter-make part so your lcr chassis number should do! when i ordered mine the lad was about 14 and didn't have a clue!
DannyC87
Mar 4, 2008
3,459
thats the chassis number yea- bottom of the windscreen - or that is the one they used from mine!
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Is there anything else I should do since im replacing the front suspension? Like mounts, links or anything?
Depends what you are replacing but if your are replacing the dampers then top mounts would be a good idea, otherwise bushes always suffer in the uk climate (winter salt etc) either plan to replace the lot or have a good look round when you get going and replace any that need it with powerflex or similar. Powerflex probably do a replacement kit
Ruddmeister
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Just out of interest, do the S3 strut braces require any modifications to fit the LCR? This sounds like a good idea to me for the quoted £53 I read above :)
No modification, to get one end under the metal support that the bonnet lifter sits on is tricky.......get this end in first, wiggle it, push it and it should slot in
Obviously you need to drill the turrets and source your own fixings
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
yea il probably best replace the top mounts as i have replacement dampers (standard ones). Not sure whether to go for powerflex or not they seem to be a bit pricey.
DannyC87
Mar 4, 2008
3,459
Yes, an S3 strut brace will fit an FR+ Diesel.
Havoc, the rear ones are made by a guy called Mike at an engineering company near a member (not sure who) - if you look in the group buy section you will see his details. I think for the gb they were around £80, so I think a one off might be more (i'm sure another GB will come up in the future though).
D.K
LCR 225
Oct 24, 2007
6,408
se london
Here's the part No for the S3 brace 8L9 805 629 A.
When I ordered mine thay never asked for a chassis No.
D.K
LCR 225
Oct 24, 2007
6,408
se london
I tryed to get them from Audi but we could'nt find the right part No, It's easyier just to get them from a DIY store, look for either M10 or M12 nut's and bolts.
delduca1
does anybody know were i can get a strut brace from cant seem to find any hald gud seen a cuple of shoddy ones which just dont cut it for me let me know please cheers nick oh btw its for a leon tdi mk1 1.9
delduca1
u got a website i can use were i can buy and get delivered its just i dont know what im buying and since my car is seat and parts are audi i dont wnat to get the wrong part
