Inverted Passenger Window
ArnieCarnie
9
Hi guys, I have a question. On my 2007/8 Ibiza Formula Sport, my passenger window appears to be inverted i.e. Push up to down and down to go up, this is the same for my convenience windows when I put the key in the door and hold it. When I lock the car and hold the key the door the drivers side window goes up and the passenger side goes down and when I unlock the car the driver side goes down and passenger side goes up.
What's going on?
dm222
1,470
46
What's going on?
coding of the window module.
it was probably replaced with an UK unit if you are from outside the UK or vice-versa.
coding must be changed.
dm222
1,470
46
Sent me a PM if you need help, I just tested on my car.
Changing the code between 00... and 02... reverses the windows behaviour.
RUM4MO
7,823
1,000
South Scotland
Any update on this problem?
dm222, will changing the coding, I'm assuming LHD<>RHD, not change the operation of both or all electric windows, I thought that the OP only had a problem with the front LHS window, meaning that the front RHS still worked as expected?
dm222
1,470
46
