Rear electric doors not closing.
Rampage
Trainee Northener
May 24, 2003
1,035
The rear electric sliding doors on my Alhambra do not close properly on cold mornings.
It only happens when it is below freezing. I guess that ice is stuck somewhere because as soon as the car is warm, the doors close properly.
Has anyone else had this problem?
baba_metca
32
They had this problem in of the reviews, I believe it was a magazine or something. Same thing. The doors could not close properly when cold. The Seat service must have some tips on how to minimize this.
myounus
Alhambra UK Northwest
Apr 9, 2018
11
Is the issue with the lock engaging or are the door not fully engaging shut?
In any case using a suitable lubricant that doesn't freeze will help. Personally I would use a marine lubricant as these are designed for sub-zero temperatures. You should be able to get these online or from your local marine stockists. :)
