Hi folks,
Apologies for appearing thick, or asking questions that have been answered before, but I'm also getting the soggy footwell symptoms on my Toledo V5 and just wanted to check a few things before I start pulling doors apart or lifting up carpets!
The front doors have always dribbled water over your feet when you open them ever since I got the car just over a year ago. At the time I just assumed it was normal and didnt think anything of it. More recently, it started misting up really badly inside, and today I came back to the car to find a small pond in the rear passenger footwell, and very wet carpet in the passenger front footwell.
I've take a look at what I'd call the '
lower outer' door seals, the long black rubber strips that run along the bottom edge of the two front doors, and on peeling back the one on the drivers side it released about a bucket full of water. The passenger side was apparently empty though, which puzzles me as thats the side where the carpets are wet. Since these seals clearly arent doing their job properly I've pulled them off to a) give them a good clean and b) let the remaining water trapped in the doors drain out.
Do I need to refit them? There is an inner seal thats built in to the car bodywork and runs the entire perimiter of the doors, so I assume that performs the moisture sealing function - why do we need the little strip at the bottom? All it appears to do is block the drainage holes in the bottom of the doors - the design seems to be such that unless the door is open the double fold in the seal actually closes up on itself and blocks the drainage holes anyway, that and any mud thats in there only seems to serve to block up the holes entirely even when you open the door.
Am I missing something fairly fundemental here? How are those bottom strips *supposed* to work? Are they just for noise reduction or something?
To carry out some other work, I have also had the passenger side door panel off and the membrane underneath *appeared* to be perfectly intact and well sealed to the door frame, so I dont think thats where water is getting through. I've also checked the pollen filter bay in the engine compartment, and thats as dry as a bone under there (I seem to recall reading that someone had found a leak through there too?).
Any thoughts / advice / comments on stuff I might be missing or misunderstanding at all? All feedback gratefully received!
Cheers!
Rich
