VCDS / VAG-COM Register - Who's got what and where?
andyhope
HEX-CAN USB, Full version.
No laptop access except when I pinch one off brother, so you'd need to supply your own
Based in Durham (DH6) - close to Peterlee, Seaham, Hartlepool, etc
PaulyboyUK
8
andyhope
Bishop Auckland here and looking to see if i can change a few settings - have a laptop etc - what cost if any and when / how can we arrange ?
andyhope
andyhope
If know you specifically how to change the coding. I'm happy to supply the cable for use with your own laptop and you code away all you want. I mainly use it for scanning my car so if you break it you have yourself to blame
PaulyboyUK
8
Spot on fella....is it an original cable? My number is 07450 260105...would only need for a day or so and would be happy to collect and return asap
Paul
andyhope
Paul
You're dreaming if you think I'm going to lend you a £300 cable on the basis you will return it when you're finished.
I don't trust ANYONE who I don't know. It's nothing personal. I don't know you for jack **** though. I never let any property I own go out my sight.
PaulyboyUK
8
sorry if i have misread your post - happy to use there!!!! i would have just as happily left a deposit or some thing - and its not taken personally!!!
smacman
VAG Diagnostic Needed
Hi, I'm new to the forum and to owning a Seat. I have an Ibiza 1.9TDi with the engine light on, car still runs fine though, and need someone to come and diagnose the fault. Is there anyone in the Didsbury/South Manchester area that can do this? Thanks
mattwillco
32
Hello all, is there anyone here able to do VCDS in the Portsmouth/Fareham/Gosport area?
I'm particularly interested in adjusting the steering feel on my mk2 2008 1.9TDi.
rashomon
13
Hi - I'm in the Harrow/Watford area
Can anyone help out with a VCDS to disable the seatbelt chime on my Seat Altea '06 model. The car keeps beeping even though the seatbelt is correctly fastened.
Thanks!
Ghost123
Desperate need of a scan!
Hi guys, is anyone on here located near hertford/Cambridgeshire way?
You'll be a lifesaver :)
joestella28
63
Hi All, is there anyone in the Norwich/Norfolk area that can read faults/test modules on a 2007 Leon FR?
I think my passenger door control module is knackered :( Beer tokens waiting....
Franko180
99 Ronnie
Apr 10, 2016
21
Midlands
Derby/Notts anyone ?!? ;) Cheers!
I know your post is from last year but I could help if you still need it.
Fully licensed / legit VCDS (VAG COM) Hex+CAN
VAG Tacho
VAG Commander
Can read / clear fault codes, data logging, cluster coding, mileage correction, VCDS general tweaks. Based in the East Midlands so not far from Notts, Derby, Chesterfield, Sheffield, Lincoln etc.
stadan
117
anyone based near or in hertfordshire that can help me disable cornering fogs and enable needle swooping via vag com?
MOFO-AUTO
Birmingham-vcds
BIRMINGHAM VCDS SERVICE
Fully licenced vcds user offering................
full diagnostic scans with fault find and reset ,service resets,activations & de-activations of functions i.e. anti hijack , seat belt warning off etc
[email protected] or txt/whatsapp 07875444404
CHEERS GUYS
luccaollie
anyone with vagtacho in Leicester area?
I want my skc code to program transponder in new key.
02 leon
cheers
dub-ha8
Newbie
Nov 21, 2005
9
London
www.vwcaddy.com
Fully registered genuine HEX-CAN-USB VCDS All cars 1992 to present.
I'm able to under take any modification that VCDS is capable of doing from basic fault scans onwards.
Based in NW London.
