just so you know, we have had many hundreds of people that have this issue, come onto SCN, get told its likely the door seals and after looking at it write it off as it doesn't appear to make any sense.
But believe us, it will be the door seals.
Unfortunately its also a job that you need to do properly, make sure the old seal is removed and the surfaces are clean before fitting new seal.
good luck.
