There is no such thing as better fluid for transfering force to brakes.
People that have gotten "better" brakes after a fluid change, would also have gotten the same resultat using tap water.
All fluids are 99,99999% non compresseable, nothing in this world are know to change a fluids state on this. And that is all brake fluid does, transfer force through its non compresseable form.
You can talk about compressible flow, but thats not something you gonna discuss unless you work at NASA or something.
EDIT: the reason people (typical track car) changes to something higher spec (and thats all it is, no magic in between the different manufacturs there) is the boiling point (both wet and dry)
Different colours of brake fluid can
help you bleed the car better to see you got all the old stuff out.
