Cold running question
bensaud
Here for the ride
May 26, 2001
417
9
Cambridge
So I replaced the thermostat last Saturday and everything was going great, temp going up to 90 and most importantly warm air in the cabin, but on Wednesday the engine started running cold again and only warms up while it's stationary, am I looking at a faulty thermostat or do I need to look elsewhere??
TIA
Ben
Sent from my Hudl 2 using Tapatalk
Connorg115
397
66
United Kingdom
I’ve heard the Ecp thermostats are shite, if I was you I’d test to make sure that the thermostat is stuck open and then go to the dealers and get a genuine thermostat
bensaud
Here for the ride
May 26, 2001
417
9
Cambridge
I don’t know if you know but you can view actual engine temps when in the car through the climate control, assuming you have climate control that is!
http://www.seatcupra.net/forums/showthread.php?t=153745
I know that his would have helped me a fair bit when I was fixing my thermostat
I've checked it through diagnostic, runs at 58 Deg while driving and heats up when stationary ☺
Connorg115
397
66
United Kingdom
Definelty thermostat then! Hahha!
I had the same trouble with mine few months ago but I used a thermostat from GSF and it’s been spot on
bensaud
Here for the ride
May 26, 2001
417
9
Cambridge
That’s it mate, silver linings!
These cars will turn you into master mechanics ahaha
Drove my 130pd from 80k to 215k over 10 years and only changed service items, this FR has had the bonnet open more in one week than the 130 in 10 years
Connorg115
397
66
United Kingdom
I know exactly how you feel I had 2 fabia vrs and nothing went wrong in the 3 years I had them oh well I like to think of it as bonding time
bensaud
Here for the ride
May 26, 2001
417
9
Cambridge
Fubar!!
masterfrodo
267
8
OK, am in stupid mode. Which code is it - is it 06.1 to check coolant temp, as I want to check if my stat is working or not
Connorg115
397
66
United Kingdom
do you mean through the climate control if so it is
press and hold recirculate button then 'up' key, then press '+' to number 51
then recirculate button again
should stay on 90C
masterfrodo
267
8
Ok. Did the code today, and it's 90 degrees. And yet my dash gauge shows 1/4 temp. So maybe the sender isn't too clever. Changed it last year as dash wasn't showing any temp. But something's not right now
19jeff89
67
Ecp stat on left genuine stat on right as you can see the difference in spring is nearly twice as thick
Sent from my SM-G930F using Tapatalk
