Fitting facelift tail lights? WHO HAS THE GUIDE that was made up by member??
devJORD
OBD11 Wizard
Nov 14, 2014
387
Before I got the new FR I was looking into doing this. Basically it's a straight swap.
THE CATCH:
You will need access to VAG-COM to enable LED mode or something like that. Some CPU's don't support LED mode and some do. However, if it doesn't support LED mode you can just disable rear light diagnostics to remove warning lights. The issue with that is obviously you don't know when your bulbs gone. But it's LED so that shouldn't happen anytime soon.
Edit:
I found the thread I was reading a few months back which basically confirms what I'm saying and has a bit more detail: http://www.seatcupra.net/forums/showthread.php?t=364843&highlight=Ibiza+LED+rear+lights&page=6
Lefty
16
Is this guide still about? I've got some on the way and need to disable it or whatever.
