Listers - Parts
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » Engine Discussion » TDi - SEAT Diesel specific topics » TDi Tuning
TDi Tuning Hybrid Turbo's, Chips, Software for Diesels. All models covered
Reply
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 23-12-2012, 00:32   #21
joshy514
Fleet Air Arm by ability.
joshy514's Avatar
joshy514 has 10 points
On the topics of deleting the egr, if I was to remove it would it be easier to clean the inlet by taking the inlet off? Just to stop shite getting anywhere?
__________________
MY2004 Black LCR : 3" Blueflame Turbo Back : Jabbasport Heatshield : Pipercross Filter : 2.0T Coils : Liquid Gauge :
joshy514 is offline   Reply With Quote
Old 23-12-2012, 01:13   #22
Seatmann
Rough around the edges
Seatmann's Avatar
Seatmann has 20 points
Yes definitely, take the intake manifold off and also, turn the engine to close the valves for each cylinder and with something to scrape get the crud out on the ports. You can use a modified hoover attachment or compressed air to clear the stuff out.
If it's just a bit greasy I wouldn't bother but if they are pretty bad then I would clean them too.
All you need to do is pop off the rocker cover then turn the engine so that the lobes point up for each cylinder in turn and do them one at a time.
__________________
2001 Mk4 golf Estate (Leon in disguise), 1.9tdi, Bosio PP764 nozzles, 35mm drop.
Custom tune by Nytrixtuning
Seatmann is offline   Reply With Quote
Old 23-12-2012, 10:06   #23
joshy514
joshy514's Avatar
How hard is it to take the egr and inlet manifold off? Is there an easy way? Seatman you definitely seem to know your shit on these engines!
__________________
Old 23-12-2012, 14:19   #24
Seatmann
Seatmann's Avatar
It should be fairly easy to take off but it depends on how good/bad the bolts are. There's two below the egr for the flexi pipe, three to connect it to the intake mani and six hold the intake mani on.
Get an allen key on each one of the egr ones first and make sure they can come loose before trying to take any right out. If you come across a tricky one get it out first before taking the rest out, that way if you can't get it out at least the car's not left sitting in bits lol.
Do the same with the intake mani.
Some you wont really be able to see but you should be able to feel your way around, just make sure the allen key is fully home before trying to turn and you'll maybe need to use a ring spanner or something for extra leverage.
__________________
Old 28-12-2012, 18:43   #25
JordanMck
Posts: n/a
Light goes on and off on mine sometimes
Old 22-05-2013, 15:31   #26
fr 150 boy
fr 150 boy's Avatar
fr 150 boy has 10 points
Quote:
Me too
fr 150 boy is offline   Reply With Quote
Old 04-11-2016, 02:34   #27
subzdarg2015
Newbie
subzdarg2015 has 10 points
Wink
Egr van be mapped out on 55plate audi a3s without a doubt lol had about 7 done now no egr at all an no lights witch eva mapper told u the egr cant be mapped out must be a generic mapper who has no.clue as ive had 7 to 8 done an some in 2011 so defo not a new thing available
subzdarg2015 is offline   Reply With Quote
Old 09-09-2017, 20:00   #28
Rosskie
Rosskie has 10 points
Resurrecting...
Tried to turn down my EGR with VCDS, went into engine, put in the secure login, but channel 10 adaptation wasn't an option. Just occurred to me, maybe the engine needed to be running??
That was on a 60 plate mk2 CR170.
I then tried on our other leon out of interest, 15 plate mk3 1.4tdi ST, put in the secure login, and adaptation channel 10 was there, thing like idle speed were listed but nothing about the EGR. There were no clear channel numbers such as the required channel 3. Also the stored values for idle speed was 780 I think, which isn't the expected format according to the VCDS wiki...
Using genuine cable and most up to date VCDS.
Anyone turned their EGR down on an mk2 CR170 with vcds able to advise? Not fussed about the other leon, yet...
cheers
Rosskie is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 256
170xl, 1986brandon1, 747_727, aceman, Adam4D, adrianofrcarlos, Al-Batson92, Alex4o0, allbutt55, alyraver, Alzak, Al_Cordoba_King, andrewhughes12, AndrewJB, Andy360, andypandypoos, andyspencer, anthony-b, APNess, asquith_4, atsimas, aviaa25, Ayze, backler87, Badger, beezaturbo, BenG, Bickerton, big rich, big_wig_074, BlackCupraa, boabym, Brettyboy, bruceR, Bully007, Buttons, carlosfilippsen, CharlesTheTog, charlesz1066, cheeksey, chichee, chris205, ChrisHuddie, chrissyboy, cl1988, clag, coogie, cordoba175, coronah, Cozzycol, Cuffy, Cupra Ross, cupra.al, cupradan, cuprar51, Curtiz, cypher007, d1n93r, dafyddjones, damo :-), Dan FR, Danleonfrtdi, dann2707, Dan_90, darkhorse, dave king, DaveIbiza, daveyboy32, davidif, dday, dean1980, Dean_dubber, Designtime, dgjdrummer, dillo, Disco_Mikey, dw911, EB-80, ebo007, Eggs, elmunkee, epts2008, Eric87, F2 Ed, Fishy, fmaclennan, fossie, fr 150 boy, FR_MATT, Gabor, gac, gaz1211, gdjohny, Gizza, greenhearts54, Gregsupercopa12, Grifftdi, GTJEDI, Havsgaard, Heathy, HIGHLAND-FR, his-n-her-scoob, hMeco, hoger954, Hou, hungabunga, ibiza95, IBIZA_W1LL, imikk3, iNeoTom, itsonlymoney, J44APX, J5HDK, jackgibs, jake-1991, Jake9119, jakeycrx, james12, Jamesemt, jimbo_h, John-Cupra_TDI, JohnnyRob, john_tdi, jonnny2012, jonnyht, Jonsyb, JPS3290, jreedy, JR_130, Just Waxed, Justinio, k100thw, kare, KarlB1, kazzy, kennedyuk2001, kevlaa, kobchai, kustom, lamchops, Lamd150, Laser, lctdi, LEE69, leero783, loopydoo2002, Louis frd, louma84, Lukesmith93, M18nye, Mac, Madman0405, Mao, MarcFennell, MarkWales, mark_eisner, Masterkm, Matt-V5-Duffy, MAZAR, mdmay, mickyp1989, milner575, Misko, Miss24, MJ, mk4 cupra, Mobo, MOE16V, MrFishFR, mr_mufy, Muttley, MWG, N417H4N, nigxl, Niktron, notquiteacupra, Number12, p11lkw, patty101, Paul43, pete fr, Peter 87, Phil_JJ, poliq, Priezti, Primey86, puchos, rackha, rainbird, RaviR50, Raziel, Red ibiza, redlinemike, reefer24131, Rich.1986, rich.h44, Richy!!!, RicoFR, ridge-racer, rob-d, Rosskie, rubeus hagrid, Rusty2k, S10EAT, scooter188, scotteg, seagully, seancave, seatleon2012, Seatmann, skinny04, skipbrown, Skyrocket, SLeonTim, smokeyjoe, SNAP-ON, snk, Snower20vt, SpawnAgain, spud31, sri_130, sssstew, sterae21, steve7786, Stu-, subzdarg2015, SUPER-MATT, swedey21, t111bul, tdi_swedge, theoldboy, theo_1984, THFC, titanium4d, tomblake1992, tommycx, towcester vag, treborleon, troupy, truCido, Trx-33, turboboy, u0543, vagman2001, verbal_kint, viperoni, volkzbitz69, vroomtshh, whitewhip, WHITE_FR4, WHOZBOSS, wikkiwahwah, WindyMills, wrayvon, yeha, YTS
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
