Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 09-06-2009, 19:41   #1
qwert
qwert has 10 points
Removing steering wheel and airbag
Ok, I've got the tools and a guide. Just after any pointers or tips from people who have done this before. Keep getting told the airbag light will come on once its reconnected, or that it will blow up in my face, and does the fuse need to come out as well? Ta
qwert is offline   Reply With Quote
Old 09-06-2009, 19:45   #2
DKershaw
1.4 Sport
DKershaw's Avatar
DKershaw has 10 points
twitchy bum time might be a good idea to disconnect the battery !!!!
DKershaw is offline   Reply With Quote
Old 09-06-2009, 19:51   #3
Guinness
Finally got the BMW
Guinness's Avatar
Guinness has 10 points
people reckon, note people not me as I have not done it. that once the power is disconnected then its not possible for it to go off, so its probably fair to assume that long as you dont damage it when the battery is disconnected then it can be changed relatively easily. The airbag looks reasonably simple to change anyway
__________________
1.9TDI Mk4 Ibiza
Guinness is offline   Reply With Quote
Old 09-06-2009, 19:53   #4
beezanick
Senior Member
beezanick's Avatar
beezanick has 10 points
Disconnect the battery and leave it for 30mins before playing with the airbag, it will give it a chance to power down. This will prevent ignition or warning lights. Ensure you have connected it all back up before reconnecting the battery aswell.
When removing the steering wheel make a note of the position the locking nut is at so you can get the correct torgue if you dont know the accurate figure or dont have a torque wrentch. Also make a mark on the nut with a permanent marker so you know howmany times it has been off. The locktight is good for 5 removals before you need a new bolt. Finaly, ensure you know the position of the wheel in relation to the shaft so you can replace it correctly. Most have a mark on them, but make one if you need to.
__________________
Mk4 52 plate 130TDi sport - in BLACK
beezanick is offline   Reply With Quote
Old 09-06-2009, 22:00   #5
qwert
qwert has 10 points
cheers chaps, fitting cruise so will let you know how it goes.
Old 09-06-2009, 22:15   #6
beezanick
Senior Member
beezanick's Avatar
Good luck! Its quite a simple job if you are confident with wiring diagrams. Ive done the conversion if you need any help
__________________
Old 10-06-2009, 10:52   #7
NickyJam
FR - gone, not forgotten
NickyJam's Avatar
NickyJam has 10 points
the airbag shouldn't go off even with the battery connected...it's a safety precaution that is undertaken to prevent the unlikely event from happening
my local mechanic works daily with airbags and has never turned the battery off, as long as the ignition is off you'll be ok
as for the light coming on, this is not the case unless you fit a new airbag with a different resistance rating (or if there is a fault obviously)
__________________
'13-present A5 2.0 TDi S-Line Quattro | '08-'13 Ibiza FR TDi 5dr
NickyJam is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 63
20 valve ted, alexbailey12, andye1, angrymaus, Arnoldo, aymen_a22, B1ADE5, bald_eagle, Bassedout, beavz_28, beezanick, benny12357, bogdancristiann, borisvanhalen, cbr40017, chris4500uk, creatz, crookiecrook, cupra.al, CupraElliott, dann2707, darkhorse, DarkSeat, diddy6161, DKershaw, dm222, DSUK, Elliman98, Fox god, Glennolls, Guinness, Indy, james.l, jamest87, killbot, kingy89, Konijntjes, laawtytdi, Leigh15, living2xs, lizard2k5, luna fr, matfennell, MATTCR, milburnj, MisterE, Mobo, monk3y303, MPJ88, Nef, Neo, NickyJam, Proff_CUPRA 180, qwert, Rick1.8t, RUM4MO, S7UYJ, Sjdickso, Stewie14, Tricky Red, Wilson9, zdimeski
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Removing Steering Wheel StokieShinobi Leon Mk1 17 01-01-2010 12:48
Removing steering wheel Guinness Ibiza Mk4 7 05-02-2008 01:45
Ibiza Steering Wheel Help Please tonydadams Ibiza Mk4 2 08-01-2008 13:28
Steering Wheel Help Please tonydadams Ibiza Mk4 4 30-12-2007 18:52
Will a cupra airbag fit an R32 steering wheel? Neil_Ireland Leon Mk1 7 17-04-2007 14:59
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
