Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk2
Leon Mk2 For all topics relating to the Mk2 Leon
Reply
Thread Tools Rate Thread Display Modes
Old 11-11-2009, 17:38   #1
rudgey
Mk2 Leon TFSI Sport '06
rudgey has 10 points
Adjusted steering wheel then airbag light came on!!!
Hi all,
Adjusted my steering wheel today and the airbag light has come on! Is it advisable to just delete the error with vag-com (and see if it comes back) or should i take it straight to the garage? Just looking for advice as obvisouly it's potentialy dangerous?
Cheers guys!
rudgey is offline   Reply With Quote
Old 12-11-2009, 00:26   #2
rudgey
Checked with vagcom and heres the code:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Deleted the DTC and it hasn't come back as yet, should i be worried?
Old 12-11-2009, 10:31   #3
FAST AL
Senior Member
FAST AL's Avatar
FAST AL has 10 points
I think if you just delete it then it only cancels out the warning light hence not curing the actual underlying cause.Is it still in warrany mate? If so get it checked out at the dealers just to be sure its safe.
Just my opinion.Could be totally off track though.
__________________
:New LEON FR TDI ZENITH GREY.Gardex protection.Seatcupra.net stickers.Auto emocion sticker.Genuine Seat FR badges on each wing.Rear parking sensors.High gloss black front grille with honeycomb insert.Not much really.Just a nice fast car.
FAST AL is offline   Reply With Quote
Old 12-11-2009, 13:00   #4
rudgey
Out of warranty tbh AL! If it comes back i'll get a garage to look at it i think! The MIL'll come back on if fault is still there i believe!
Old 12-11-2009, 13:39   #5
FAST AL
Senior Member
FAST AL's Avatar
Ye but if it doesnt come back will you still have a nackered airbag ?
Risk it if u like but you only live once.I know I would get mine checked out but I'm still in warranty for another year.
Oh the joys of warranty's me thinks.
__________________
Old 12-11-2009, 14:47   #6
rudgey
True AL true! I'm gonna get on the phone to midland VW now!
Just spoke to midland VW they've said not to worry unless it comes back (i.e. theres no serious fault if it's off) and occassionaly moving the steering wheel/seat too quickly can set off the MIL! Still a bit worried tho tbh!
Old 12-11-2009, 16:15   #7
FAST AL
Senior Member
FAST AL's Avatar
Sounds as though its ok now then mate.
The fault should show up again if theres an actual problem.
__________________
Old 12-11-2009, 18:10   #8
nc30rider
nc30rider's Avatar
nc30rider has 10 points
Should be OK, I see this kind of issue all the time. Especially Renault front seatbelt pretensioners. Sometimes if you move the seat back and forth it puts the airbag light on.
The movement of the connectors is enough to cause a variation in the resistance of the circuit, thus causing the ECU to throw up a fault. If it happens again, get someone to open and close the connections a few times, then clear the faults. Should be fine after that.
It is only a real issue if it happens when you turn the steering wheel. This is probably an airbag slip-ring/clock-spring problem. Unfortunately that is a replacement only!
When the light is on, the only dangerous thing that will happen is the airbags/pretentioners will NOT deploy in an accident. The system is deactivated once the light comes on.
__________________
Emocion Red Leon TDI FR 184 Tech Pack, Titanium Pack, Convenience Pack, Seat Sound Pack & Alcantara.
nc30rider is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 42
-pseudonymous-, 22ssingh, alx_chung, AndyCon, AnthonyDi, Bedlam, cheungy, coggie, dannychapman10, dave_ph, doll, FAST AL, GainfulShrimp, gard_ian8, Gazguthrie, Haddock, HotHatchSteve, IanG, Jace, jcp, jezyg, JMP, johnbev, Jon TDI, kareemsafwat, Leigh15, LeonMunkee, Marshall, Mickylad, Nath., nc30rider, NickP, NinjaPirateUK, n_olympios, predo, Ptar64, Rampage, ross27, rudgey, SeanCorky, singh123, treborleon
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help.. abs and power steering light flashing intermittently Kimmsy Ibiza Mk4 7 03-01-2018 15:18
Steering wheel illumination dean16v Ibiza Mk4 5 03-05-2009 20:14
Airbag Light OllieL Ibiza Mk2 3 31-07-2008 20:21
Choice of steering wheel Nutkin Leon Mk1 5 16-03-2008 20:23
steering wheel opinions please! skahigh Leon Mk1 52 29-10-2007 15:58
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
