Leon tdi alternator pulley fell off
gummybear
Hi there,
Has anyone had an alternator pulley fall off their leon whilst driving?
Mine came off on thursday night (1st April of all days!), first thing I noticed was the battery light came on and the power stearing failed as you would expect, then a bang as the pulley departed the car and hit the underside of the floorpan, looked in my rear view mirror and watched it disappear down the road( SH*T) had an hours drive remaining and had to nurse the poor thing home.
Picked up an exchange 90 Amp unit for £150 and a replacement belt for around £20 odd.
I have heard of this happening to others some time ago, is the cause specifically the pulley clutch? Is it much of a job changing the unit?
Cheers :(
gummybear
That's really unusual, they are normally a pig to get off!
Yes, I would have said the same, but from what I've just read on some old posts some alternators were fitted with one way clutches on the pulleys and it's these that seem to cause the problem.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Pretty common if the one way pulley seizes up as when the engine rocks back half a turn when the engine is turned off it undoes them. Was a recall on the Alhambra but never on the Leon.
danny20vt
going back to basics
not an alternator pulley, but i've had a timing pulley snap off a few years back on a Rover, funny thing is, it actually shot down the road faster than the car and I managed to get 4 miles back home before the timing actualy went and forked the engine:cartman:
gummybear
alternator pulley
Mine snapped off a week before it was 12 months old.
Rang seat assistance, got it done under warranty.
Oh dear, that does'nt sound good.
I've had my 03 leon for just over a year now, it's done 82 000 miles, I changed the turbo just after christmas as it had been leaking oil badly into the induction side of the engine for a number of weeks, that was £380 from turbo solutions and took me about 5 hours to fit at work what with changing bits over and cleaning etc, just what you need after christmas!
It's been an expensive couple of months! fitted the re-con alternator today (3rd April) that took about 3 hours, you have to remove the power steering pump and the drive belt tensioner just to get to the alternator bolts, even then the alternator is still a tight squeeze past the radiator fan, coolant pipe and mounting bracket etc.
While were on the subject here's a quote from a website I found regarding the alternator pulley:
The Clutch Alternator Pulley was pioneered by Audi, BMW, Mercedes, Seat and Volkswagen.The idea of which was to reduce possibility of sudden snatch when coming down from high revs such as motorway driving to a standing stop thus prolonging the life of expensive automatic tensioners. Unfortunately the pulley design was such that they failed after a relatively short period of time and that they are a costly service item.
Say no more :headhurt:
lil3520
IBIZA 1.9 TDI SPORT 08
Nov 26, 2006
3,001
21
ALCESTER, WARWICKSHIRE
must be my fast driving :cry:
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
what is the test for a faulty alternator clutch?
Very easy.
Take a thin screw driver and VERY carefully with the engine off see if you can rotate the fan blade within the alternator through the vent slots. You should be able to freely move it one way but not the other.
trebormint
333
Swindon
Twigworth Breakers in Gloucester.
They do alternator and starter motor repairs on site.
Took him, oh, all of 5 mins!
Feb 22, 2009
3,618
South Wales
part 2 in this picture
part number 038903315F
dean@pioneer
still having this problem keep forgetting techie's advice to check the alternator - noticed the tensioner bouncing about a lot. maybe its this tensioner which is t fault
Hi Mark
It will most likely be a seized alternator pulley. We've replaced loads of these for your exact same symptoms as it causes the tensioner to jump about due to the alt' pulley seizing. Replace this first as its an easy procedure and not too expensive compared to replacing the tensioner.
Dean
