Changing the Steering Weight
raul_sbd
I found this in one post that was posted in here on Seat MK4 forum a while ago;
"Whilst I was out playing with Vag-Com I thought I'd have a go at changing the steering weight.
The procedure ( for those who are interested ) is dead simple.
Open the steering assist module
click recode -07
take note of the value, on mine it was 10111
change it
mine is now 10151
its more work to steer but you get much more back from it. Steering is more positive and less twitchy. I may well knock it down to 141 to ease it up a bit.
All round dead easy mod
Anyone has tried? i have a seat ibiza petrol 56 anyone has tried in a petrol version or should it be the same?
raul_sbd
Definetly a VAG Garage will change it... arround 30£... but i think should be worthy
rf860
3,570
scotland
@ raul sbd sorry i never got back to you on your other thread. I tried asking the dealer if they could adjust the weight and they played dumb and said that 'there was no problem' with the weight of the steering therefore would not adjust it :(
Blanco92
www.racedriversinc.com
Apr 11, 2010
2,496
Bournemouth/Cheshire
I changed it like the OP says, but changed it back again because I didn't like it as much. Yes it gives you more feel through corners, but it made parking more labourious. I couldn't be arsed. :lol:
raul_sbd
rf860 right... yesterday finally i change ittt!!!! ;) im now in 10151 setting and it makes a big difference the car feels more solid and steering more responsive and settle... all that i did is to buy a cable in ebay and use the sofware that was coming with. vcds little.. enables you to change this setting for the power assistance!!!
1000baird
1.4 power
Feb 8, 2010
137
id be very interested in changing the steering weight
do you have a link to the ebay cable you used?
1000baird
1.4 power
Feb 8, 2010
137
got my steering weight sorted
highly recommended to anyone that dislikes their light/unresponsive steering:)
Aug 18, 2007
350
I'm from windermere, cumbria.. But have family down your direction.
So I'm often that way, may be able to sort something out!?
Blanco92
Apr 11, 2010
2,496
yeah i got that installed, think its the drivers for the cable i cant get working.
Check that the COM port (or technically, virtual COM port) that VCDS/VAG-COM uses matches the COM port that your VCDS USB cable is using.
To check, go into device manager on your laptop and see what COM port you're using (it should be between 1 and 4), then ensure VCDS (in the options section within the program) is using the same COM port number.
Pete.
253
Aberdeen
Nice one mate got it working and changed the steering weight to 10151, does it go any higher because mine was already on 10131 so doesn’t really feel much difference and still feels to light.
