Thanks Tom. So I am guessing this kit also comes with brackets to secure the FMIC to the OE crash bar?
The fog lamps are a little dulls but do work surprisingly well when used for what they were designed for I've found and besides, I'm all about keeping it OE
*cough* Is someone falling back in love with his LCR again *cough*
Yes indeed mate, brackets all nuts/bolts and fixings are there. I bought the kit thinking 'ok it's not a Forge so I might have to do some modifying with the pipework route etc' but it wasn't as bad as I thought. The Forge would be easier to fit, no question imo.
I didn't spend enough time adjusting the
lower pipework, so couldn't 100% say that the fogs will still remain and you can keep your OE look guaranteed! I took a slight risk and lost the fogs as it went on easier without them re-fitted. One of those things I guess..
I can only now think of more airflow due to lack of fogs, and that if I still had them in, the glow would look yellow and dated compared to the hid+LED sides setup I'm running in the headlights.
If I wanted 100% OE look now I'd spent a bit more and get the Forge to be safe..
I've been really pleased with the TX's performance though and it's just now a matter of seeing how it copes with the higher boost of stage 2.
I fell in love with mine again over the weekend! Only takes a clean, a small rear washer fix and a polished charge pipe
