Has any one had the same/similar issue that my 1.4 FR is suffering with at the mo?
When in Sport mode and the ignition is then turned off. On the restart to all intents I.e the mode switch is lit up and the screen says it is in Sport mode but the engine response defaults to normal, the door lights also default to white(normal mode) but the steering remains as it should for Sport mode. If I hit the the 'Sport' on the screen then it all works as it should. The mode function should retain the last setting it in it's memory according to the book.
My dealer is at the moment unable to effect a cure but Seat Technical are involved so hopefully it will be resolved soon.
