Cupra wheel hop, sorted...
Syndrome
68
Wiltshire
...mostly anyway :p
Thought I'd share my impression on a little mod I have been bombing around with for the last few weeks that seems to have improved my Cupra from a great car with a pretty large and annoying fly in the ointment to a fantastic car and as a real Brucey bonus it only costs about £50 to do.
I do like detail, so this may be a case of TL;DR or teaching your granny how to suck eggs for some, but for those of you sick of the wheel hop stick with me and I'll explain it as best I can, for the rest who don't want the waffling, skip to the TL;DR bit :D
Anyone who has driven a Cupra with a bit of gusto will probably have experienced the two scenarios:
1) You give it a bit of beans from a standstill and you get a handful of annoying wheel hops which sound like the car has fallen off a set of jack stands about 5 times in rapid succession
2) You are driving around giving it the beans when you hit a relatively small imperfection in the road (roundabouts were my favourite) and you get that falling off the stands noise again
Neither of these events were something that I was happy with in my new car so I did a little digging into wheel hop and the MQB platform.
If you really want to know the nerdy science I found this article quite helpful http://www.mc2racing.com/tech/20061012a/
Long story short after a bit of digging on mainly the USA based forums for the Golf GTI Mk7 the common consensus was the weak link was the Torque Arm or Lower Engine Mount, specifically the bushing. This part prevents the engine from rocking back and forth too much while under power by use of an arm attached to the engine, it also dampens some of the vibrations from the engine.
This arm is bolted to the cross-member using a bushing... a bushing which, as far as I can discern, is shared across the MQB platform... yep the shame rubber bushing that stops a 1.4TSI 138bhp lump from rocking back and forth under its own steam is doing the same job for the 2.0TSI 276bhp lump. While I get the whole "shared platform to keep costs down" thing, I would have thought it would be wise to beef up certain areas of a car for higher output models, certainly seen as this is only one of three mounts bolting the powerplant to the chassis.
Now the fix, basically, is to stiffen this bushing up so it can't flex too much, however stiffen it up too much and you will feel every vibration through the engine.
There are a number of retailers that already sell fixes in various guises for this issue, one is the "VWR Uprated Lower Engine Mount and Torque Link", a pretty fearsome looking bit of kit, however for me it looks like it would be too stiff (makes Kenneth Williams noises), it requires a lot of work to get it fitted and it isn't cheap. The expense bit isn't really the issue but my car spends most of its time on the motorway and I don't fancy having my eyes vibrated out while travelling up the M5, also if there is an issue with the car and I need to take it to SEAT, I'd like to be able to remove the mod, for obvious reasons, in half an hour as opposed to half a day.
Answer? Torque Arm insert.
It is basically a moulded piece of Polyurethane that fits inside the gaps of the stock bushing, it will firm up the bushing making the car less prone to wheel hop but is easy to install and remove.
Two companies make these, Neuspeed and Black Forest Industries. BFI do two compounds, street and track, Neuspeed do one street compound. I picked Neuspeed as it was easily available in the UK and looked like a better design.
Both items fit in pretty much the same way, you remove the bolt running through the stock bushing, pop the insert in and bolt it back together using a specially designed washer. In BFI’s case you also use their own supplied bolt.
Just incase you were wondering, here are the fitting instructions for the two:
www.neuspeed.com/media/attachments/345_22.10.92.pdf
http://blackforestindustries.com/FSitems/MQB_Torque_Arm_Insert_Instructions.pdf
TL;DR
Hi again! I fitted the Neuspeed Torque Arm Insert a couple of weeks ago and I have been impressed, it cost £55 from a VWG Specialist and required 30 minutes of my time to fit.
I would say 80-90% of the wheel hop has been eliminated, it is harder to provoke and when it does hop, it does it for less than half the time it did before and it is nowhere near as vicious. It now feels as if it has gone over a small bump at about 30mph as opposed to falling off a cliff.
Personally I have not noticed a huge difference in shifting as I have a DSG car, but it does feel a little more immediate when I nail it and a little less “rubbery” when accelerating, not a huge difference I’ll admit.
The insert does transmit a small amount of vibration into the car, depending on your viewpoint it can be either a good thing or a bad thing, for me I like it. The car seems a little more vocal and communicative and less clinical now as you can feel what the engine is doing a bit more, it’s nothing offensive just a little fizz you can feel as a driver. It also seems to produce a nice roar in the cabin when you’re having fun, but it doesn’t sound fake like the Soundaktor nor is it intrusive.
Some of the USA forums have reported annoying vibrations in various situations such as idling, A/C on etc, there are only two times I really notice it.
First is starting the engine, it has a bit more of a kick to it but it lasts a fraction of a second, it could be annoying if you use start/stop 20x a day and/or are really sensitive but I am not bothered by it.
Second is reverse and I’ll be brutally honest here if it vibrated while idling, moving, or with the A/C on like it does in reverse, I would remove the insert. It only feels vibey in reverse with no brake applied (again DSG car), it isn’t shaking your eyes out but if it happened while going forward it would quickly become tedious, my thinking however is how much time do you spend in reverse? For the amount of wheel hop it has quashed it is a pretty small sacrifice.
At some point I will probably try the BFI Track Insert but I suspect that would be too harsh for a daily driver.
For anyone who has stuck through to the end of my essay, I hope this helps and it will be released in Paperback come the New Year :p
Reactions: missmouse
Ocularis
492
Northampton
Good write up mate, worth a look I think although thankfully im yet to have any wheel hop but im sure I will do when i swap over to the summer wheels.
jimiC
314
South Derbyshire
thank you, yes that was a 'committed' read :D i've only experienced the hop a few times which i thought could be remedied with the next tyre change as some have noted on here. id seen a similar solution to yours on youtube, ECSTuning fitted what they referred to as a dogbone mount to a Golf 5. i thought it sounded a reasonable option but hadn't read of anyone fitting one to a SEAT.
https://www.youtube.com/watch?v=LH7MhZvSklE
Syndrome
68
Wiltshire
Lol, cheers guys glad you could make it through. Sorry Andrew no Kindle version but I'm in talks with Nic Cage for the film, that guy will take any role!
Just so you know I have PSC2 tyres fitted and was still pretty savage. When they run out I will probably look at PSS tyres as they seem to have much more positive feedback than the stock Bridgestones.
jimiC
314
South Derbyshire
ok thanks for the heads-up, i've a few thousand left with the 050's so hopefully a favourable solution can be found that doesn't involve delving into a grease pot to install one of these :)
Syndrome
68
Wiltshire
That's what I'm about to swap over to... doh!
Very good tyres. I am 2k miles in and they do seem to wear fast, I think I'll need a new set by 6k. Can easily get wheel spin in 1st but only get it in 2nd if the road condition or weather is pants and I am poking her with a big stick. That being said I had a brief moment of slip in 4th the other day, greasy B road, lashing with rain and I was giving her some grief :D
If you can jack up the car and change a wheel you can do this, it is laughably easy to do and really does the car wonders.
Ocularis
492
Northampton
Yeah i think the stock depth is under 6mm so you dont get a lot of tread on them brand new. I'll see how they go and then prob do the same and go PSS... anyway, enough off topic, sorry!
brentnall
47
Newcastle Upon Tyne, UK
Impressive, many thanks for that interesting read.
Can you give us any tips regarding where they can be sourced in the UK from your research?
A cursory google search provides mainly US links with exorbitant shipping costs...
Orbiter
Orbiter
Apr 3, 2015
119
My first Mini also used to suffer from this, it however had done about 80.000 miles. A new bush on the top engine tie-rod helped but didnt cure. So this problem which existed in the 1960 transverse engine made by BMC still exists 55 years later. Having said that you have probably got over 200 more bhp than the standard old Mini.
GrahamFR
Now AMG Powered
Dec 10, 2008
4,235
Barnsley or Burton
4 times the price i'm afraid, not sure if its 4 times the result.
Awesome gti will post it out to you http://www.awesomegti.com/neuspeed-engine-torque-arm-insert
kentbloke
134
Greenhithe KENT
Syndrome
68
Wiltshire
That's the one I felt would have been too savage, it looks like a brilliant bit of kit but I do still want compliance in it, plus that seems to be around the £180 mark.
Looking at some of the USA guys you can easily over do-it here and end up with a very vibey car, not so bad if it's a race car but in my case I'd rather not shake my eyes out of my skull while pottering to Surrey.
Thanks :D
GrahamFR already found it, I got the Neuspeed MQB insert from Awesome in Manchester while I was passing through.
Syndrome
68
Wiltshire
Ive sent them Email asking the question with all the car details, hopefully they we get back to me in a day or so as i see they are based in Oz. They all do look much alike i must admit.
Good spot, they do look identical.
If you get a definitive answer from anyone or take the £25 punt let me know and I'll add it into my first post. If I pass Manchester again I might see if they have both in stock and drop in so I can see if there is a massive difference side-by-side.
If the Superpro is made a little firmer I would probably try it myself just to see.
kentbloke
134
Greenhithe KENT
It would seem the numbers at the end of the part number ie 70/80/90 is down to how firm/stiff they are 90 being the race or stiffest. Il post the answef soon as i hear back from Superpro
jimiC
314
South Derbyshire
yes, i use a trolley jack but looking at that US video of the guy bashing it in with a hammer (which seemed a little futile) i presumed it to be more awkward without a pro lift or ramps :)
