instructions for hand brake adjustment.
Handbrake: adjustment
Notet The rear brakes are self-adjusting, so the handbrake does not require adjustment in normal operation. Re-adjustment is only necessary after renewing handbrake cables, brake callipers, brake pads or brake discs.
t The footbrake system must be bled and must be functioning properly.
t Handbrake lever, handbrake cables and brackets must be fully installed.
– Insert the lever at the brake callipers using feeler gauges; dimension A = 1.5 mm.
– Press the brake pedal firmly at least three times.
– Remove centre arm rest → body assembly work internal; Rep. gr.68.
NoteFor removing the support foot of the centre armrest, you do not have to remove the centre console.
– Remove the support foot for the centre console → bodywork, Interior fitting work; Rep. gr.68.
For illustration purposes, the diagram shows the handbrake lever after it has been removed from the vehicle.
– Press release button -2-. Both catch hooks should catch the handbrake cable eyes
– Let go of the release button.
– Firmly pull handbrake lever 3 times.
Place handbrake lever in rest position.
– Press release button. Both catch hooks should catch the handbrake cable eyes
– Release the locking button.
– Remove feeler gauge from brake callipers.
– Check lever position at brake callipers.
– Distance A between lever and stop must be between 0 and 1.5 mm.
