Steering wheel warning in dashboard
Djito
Hallo people,
I got a problem here. I've gotten a steering wheel warning light in my dashboard and my steering wheel got very heavy. It's difficult for me to turn around corners as I have to put much effort to turn the wheels.
My seat is cordoba 2005.
I hope you can help me with this issue that I got here.
Thanks in advance.
Pimped up vario
Cordy Cruizer
Nov 20, 2009
1,291
Belfast N Ireland
Does that model year have the electric power steering assist or hydraulic? Check the condition of your battery and charging system and next would be the fluid the power steering fluid reservoir.
rodrigocswm
9
Brazil
Check the level of power steering fluid level may be low and that makes the steering is heavy. If the level is low enough to check the type of fluid used in your car and just fill the tank to the level indicated. If this is the problem you can do it without lead to a mechanical
