Hi everyone I just wondered what everyones thoughts were on some noises I am getting. Just recently when I start car whether cold or hot the engine shakes violently and with extreme noise. Tick over and running after that is absolutely fine no further noise. What could this be ? Also I have noticed when a start to engage the clutch there is a note change in the engine as you push through to fully engage the clutch the noise goes away and then back as your foot comes back up again. I have noticed also when maneuvering using just the clutch and no accelerator the engine seems to be noisier again. Engine performance is unchanged, mpg has been great. Gear change perfectly fine apart from the 1st to 2nd normal cold gear clunky from the 6 speed box which I understand to be normal. I have recently put some different oil on top up and de activated the 1st gear torque controller through carista app as car was bogging down in first. Could these changes have some bearing? I am just worried it could be the fly wheel.
Thank you everyone for all your help with this
