They are a twat, if u want to refit them and you need to remove them without breaking them take the shocker off at the hub and brake flexi and abs wire, undo the 3 bolts on the top and then pull the shocker from inside the wheel arch but tilt it to one side and give it a damn good pull, should come out then leave the black plastic cover still in, the it just pops off.
