Cold start problems. Help!
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Hi guys
I’m in need of some information please.
For a few months through summer my car has on most occasions fired up with a cold start. With the revs up high.
It’s done this even at midday in 20 degrees.
It only does it for the first fire up. Once it’s been run for a minute it won’t do it again.
It throws up no code faults.
I get that it’s a sensor which must be failing and not reading a proper temperature at initial start, but does anyone know exactly which sensor governs the cold start up activation?
Just changing out thermostats and temp senders Willy nilly would cost a packet.
Any help appreciated.
Badger5 Custom Map + TIP,
Alexis27
2,107
456
Manchester
Do you get the EPC light showing?
Warm start problems are often the crankshaft sensor. But it often throws a code
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
No. No codes. No lights.
Seems whatever isn’t reading correctly hasn’t actually failed completely.
Just a guess.
