Many of systems are not available after battery replacement
Jul 21, 2023
Hi everyone
Here is my problem:
I had to replace the battery (EFB) because previous just dead, but after that many of systems like ESC, ACC, Auto-Stop, tyre-pressure monitoring, front assist, parking assist and etc...all of them have "ERROR: ..... is not available". Ignition is working, I can drive. I also had tried to reset these errors via ELM adapters application - didnt help. Tried to reset all setting in car computer - didnt help.
Mb there is some solution before I go service?
SteveGSXR600K1
579
191
After changing the battery specs with OBD11, the main thing that got rid of most of the errors on the dash for me, apart from the 'Start-Stop', was to start the car and turn the steering wheel from lock to lock. A scan with OBD11 still shows the errors, so I just cleared them.
RUM4MO
7,851
1,007
South Scotland
I think that the OP's problem is the car's reaction to having a failed battery - and being unable to recover after fitting a new one.
I'd doubt, for this specific issue that any of the maybe needed, or desirable coding will have caused this, yes coding in a battery change is good, but this is a completely different problem/failure which was not expected to happen.
