New to VAG COM Can someone explain this to me???
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
here is the VAGCOM report from my car and its showing some faults. can any one expand for me?
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 038 906 019 NJ
Component: 1,9l R4 EDC 0000SG 9810
Coding: 00102
Shop #: WSC 06402
VSSZZZ6LZ8R022421 SEZ7Z0G3885709
1 Fault Found:
17568 - Manifold Temp Sensor (G72): Short to Ground
P1160 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 AG
Component: MABS 8.0 front H05 0002
Coding: 0002238
Shop #: WSC 06402
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q2 937 049 F
Component: 000A BN-SG. 2S36
Coding: 00012
Shop #: WSC 04767
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 923 G
Component: KOMBIINSTRUMENT VDO V02
Coding: 00405
Shop #: WSC 00000
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00017
Shop #: WSC 04767
Address 56 -------------------------------------------------------
Controller: 6L0 035 186 C
Component: seat s04 GRO 6 37
Coding: 00401
Shop #: WSC 06402
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
Cheers Steve
BeartheBruce
Ross-Tech, LLC
Apr 23, 2006
527
Near Philadelphia, PA, USA
Both are intermittent codes meaning they were set at some point but at the time of the scan, they were no longer present. I would clear the codes and see if they return unless the car is still under warranty. Then I would leave them for the dealer to see.
The temp sensor intermittent short to ground could be the sign of a temp sensor beginning to fail or the wiring between the sensor and the ECU chafing on some surface.
The other error may be a result of the temp sensor error.
st10587
Oct 4, 2007
3,669
Hindhead
many thanks for the help i found today that it was one wire on the map sensor that had rubbed through. so after re wiring the map sensor all seems to be good
