Fuse for Washer pump
AJSanderson
Ibiza Mk5 SC
Does any one know which fuse controls the washer fluid pump. The Manual is not specific. It tells you which are for the washer wipers, which are working. And it tells you which is for the headlamp washer pump - only my cars not fitted with headlamp washers.
I had a new washer pump fitted on Tuesday, used it once and now it not working. No sound from the pump motor which makes me thing the fuse is blown.
AJSanderson
Tried it at lunch time yesterday- after the sun had been on her all morning and temp was above freezing. Checked the washer fluid was not frozen. Still no good.
So I don't think it's due to the pump being frozen.
I am not getting any sound from the washer pump motor, the wipers work okay.
She's booked back in on Monday. It just annoying that I had a new pump fitting on Tuesday and it worked for one day.
phil_monk31
471
went out this morning and mine was ok, I ran it for a bit and then added more concentrate, would seem the pump was just frozen. Important thing i suppose it just not to keep tying all the time as the pump may burn out.
