Ibiza Mk4 Part Numbers List
Dec 3, 2009
1,638
1.8 20V T FR gear knob (with 5 speed)
PART NUMBER: 5P0 711 693 A
Found this on a listing on eBay so check with dealer before saying yes! but it could be what we're after
aj51 log
Haven't looked through the whole thread yet lol. I need the part numbers for the Cupra interior trim...Headliner, all 6 pillars, visors etc.
Nov 25, 2007
1,892
Derby
Iv been told that I can get a rear euro light assy from dealer
Does anyone know what the part number would be for a N/S/R sports rider light want to get rid of the reverse light and have all red lights ?
ChrisBoom
89
Highlands
Just putting a large order off to David at SERE Motors, here's a list of parts people may find useful:
6LL601171 – Cover cap (x4) Centre caps
6Q0412331B – Suspension strut storage (x2) Top mounts front
6N0412249C – Deep grove ball thrust bearing (x2) Top mount bearings front
N90536901 – Spreader rivet (x2) Bumper grille clips
N90954802 – Oval hexagon socket head bolt (x2) Front strut bolt lower
N10106402 – Hexagon collar nut (x2) Front strut nut lower
N10127707 – Hex collared bolt (x6) Strut top bolts upper
N90648402 – Hexagon head bolt (x4) Rear strut mount upper
N90517304 – Hexagon bolt (x2) Rear strut lower bolt
N10286110 – Hexagon collar nut (x2) Rear strut lower nut
N10648301 – Hex socket countersunk bolt (x2) Brake disc retaining bolt
6LL698295 – Fitting parts for AP Calipers
ChrisBoom
89
Highlands
Anyone have the part number for the clip that holds the diesel filter in to it's housing ?
2003 1.9 130TDi sport
I have finally broken mine after the 4th filter change.
Dean
Looks like the whole thing is one part:
6Q0127224C - Retainer for fuel filter
Tuneboy
Part number for the licence plate light? I don't mean the bulb, but the entire thing. I want to make a third number plate light in the middle to get a more even light distribution. If no part number available, can anyone confirm if it's the same as a Polo 9N or Golf 5 or so...?
technohippy
Anyone got part number for front coil spring for a fr tdi?
Also are the cupra springs any different? (lower stiffer?)
SknkSv
El Salvador
Where to buy?
Hi guys i want to ask you if you know where can i buy these part number online
6L0 853 665 C 01C im from El Salvador in Central America, thanks!!
ICPurvis47
I have a problem with the engine revs rising during gear changes when the engine is cold, and again when it is at full temperature, but not when it is somewhere inbetween. Took it to the Seat dealers, who used the diagnostics kit to reset the faults, drove it around for a few days, and returned to dealers, who said there were no further faults, so probably ECU is faulty. Over £250 for the ecu plus fitting. Found several ECUs on line for reasonable amounts, but apparently you have to "Unlock" the ECU so it will recognise the key fob. Please could someone tell me if this is the case, and how do I go about it? Thanks. Iain, in Rugby. '04 Ibiza 1.2
