Hmmmm has anyone done this?
I know this is a few years since the last post.
I have recently completed this mod, all you need is the correct steering wheel controller. I got the ch model as before i had changed the steering wheel i changed the cluster to the large red screen fr version so it was compatible.
Then you just need the steering wheel itself plus the correct airbag. I got the 09 fl leon fr flat bottom wheel. I then noticed the same airbag is used in the 09 onwards alteas and toledo so i got that.
Once you have the 3 items plus vcds its just a case of removing the old controller and wheel, search you tube if you are unsure of
how to do this. Install new steering wheel, make sure the dot on both the steering column and steering wheel allign correctly. Tighten the bolt to 30nm as per elsawin.
Connect the wires between the airbag and steering wheel for the horn and steering wheel controls then connect the main yellow plug to the slip ring, push the airbag all the way in until it clicks in place if it doesnt the wires are in the way.
Connect battery then open vcds go to steering wheel controller and code it in as per your vehicle. Then the install is complete just remember to do steering assist basic setting so the yellow light on the dash goes off and the steering is not heavy. See rosstech for this procedure.
Hope this helps someone wanting to do this mod
