Door lock noise
dm222
1,474
47
You not thought about getting a new car with the amount of issues you've had?
sure, but new I can't aford it right now, if I buy an used I go back to square 0, having to fix and learn how to fix things again
besides I'm not having much problems with the car latelly...
everson38
470
35
walsall
Any chance u can upload to YouTube and post a link? Phone does not support
Sent from my SM-G900F using Tapatalk
dm222
1,474
47
Noise started yesterday and today it started to not lock sometimes
dm222
1,474
47
replaced the door lock with an used unit and it's ok now, but the door requires a new elevator as disassembling it so many times it's not working perfecly now.
BTW
for those who disassembled the doors before does this have any porpose? is there a problem if I cut one, as it would make easier?
dm222
1,474
47
now the other two I didn't replace yet are giving errors, what a fail!
all four of them failed in less than 10 years.
no wonder they only used this locks untill 07/2008
03302 - Response Closing Status of Passenger's Door
008 - Implausible Signal - Intermittent
03303 - Response Closing Status of Rear Left Door
winter is comming!!!
RUM4MO
7,843
1,007
South Scotland
Sometimes life is cruel
Tomorrow is meant to be the first day of winter, try telling that to people in some parts of Scotland and Northern England, snow has already arrived!
dm222
1,474
47
Meanwhile I replaced the rear drivers side door lock, and now only the passenger door has the original door lock. I'm waiting for an ebay order to replace that one.
The ones I've been installing are from VW Passat, and I noticed the manufacturer is different, which may or may not explain the problems:
Passat: Kiekert
Ibiza: Intier
I did change my BCM coding, now with one click it only opens the drivers door, two consecutive clicks and opens all doors.
It still unlocks all four doors from the inside (maybe a security measure) but only drivers doors outside.
they usually stop working from outside first* so I hope this will prolongue the door locks life.
* I think it's because outside it locks/unlocks twice (when you enter the car / leave the car / reach 15km/h / remove the key from the ignition) in a normal use while inside only once.
It was very simple:
https://www.youtube.com/watch?v=YQkwxeR0Q-Y
RUM4MO
7,843
1,007
South Scotland
Hum, I had not thought about "one press all doors unlocked" and "auto locking" as shortening the life of these lock assemblies!
My wife's old 2002 Polo 5 door that she ran from new to 13 years 105K miles, did have "two presses all doors unlocked" though she did tend to open all doors most of the time as she would be collecting someone enroute, that car never developed any door lock issues.
I have configured all our cars to have "auto locking" as well as "one press unlocks all doors", so I hope that I don't need to get inside any doors!
dm222
1,474
47
Hi RUM4MO, fortunatly for you, you don't have the same door locks as me.
I didn't disable auto-locking.
I disassemble a door lock, and found out there is three switchs.
- 1 to control the lock state outside
- 1 to control the door state inside
- 1 to control if the door is open or close
As all doors that develop problems, stop to lock or unlock outside but still work inside fine, I hope it is the first switch above that stops working, and now if I press once only one door is unlocked outside.
The switch is a rubber thing that is pressed against by the mecanism, I guess that with to much use they fail and start to get water inside, although I did not found any problem when I disassembled it.
dm222
1,474
47
I have no idea what this noise could be...
I'm not happy ehehe, just replaced the passenger door lock 2 weeks ago, and the rear drivers 1.5 months ago, and now this!
This doesnt have an end, it seems.
