Mpps v16 problem
connahiatt48
41
Hi all..
I decided to get my own mpps v16 but am having some trouble getting it going!
I've been trying all day literally to install and it does but when trying to run the programme I get an error box with " ext-ms-win-gdi-desktop-l1-1-0 " and this continues to flash on and off untill it then shows in the grey "run New" box "problem!!!"
Could anyone give me some advice on what to do?
I had to buy a new laptop to do this as my old one was beyond economical repair and atm it feels a waste of time/money.
Many thanks In advance
Sent from my SM-G955F using Tapatalk
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
Older OS needed, issue with newest Windows 10 builds and 'older' software... Add a partition to boot in to Windows 7 and it'll work fine
connahiatt48
41
Is this a guaranteed fix?
Dont really wanna fork out more money to change the software on the laptop if it's not gonna solve my problem.
Thanks for your advice!
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
Google your error code....
Fork out? Its an easy DIY, plenty of guides online.... Shrink current partition, create new partition in the newly release space, download one of the pre activated windows 7 ISOs available online and install it
connahiatt48
41
I've googled my error code must be 100times today and there's no fix.
The dll files aren't present on Windows 10 and you cant download them anywhere.
Yes, fork out.. I'm not hugely into computers etc so I would have to pay somone to do it for me.
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
Have you run the program with admin privileges? My older MPPS (V13) requires this in order to run, and won't run at all unless the cable is plugged in with the drivers for it installed correctly
Have you disabled Windows Defender/Smartscreen as it tends not to like loaders and modified/cracked files?
Other than that I can't help sorry, 'Problem' doesn't help much and I can't read chinese
yanivkoval
152
32
Hi OP,
Try running in compatibility mode for Windows 7.
Right click on the exe file and navigate to the compatibility tab.
Tick the “run this program in compatibility mode for”.
Select Windows 7 from the list.
Tick the run this program as an administrator.
Example image below.
connahiatt48
41
Hi OP,
Hi mate.
I've just done this step by step and it is still doing the same thing.
The conclusion I have come to is that I need to run - Windows 7 (another task for me to try and conquer without destroying my laptop)
Is it worth mentioning that I'm actually running - Windows 10 pro - at present?
I appreciate your help
yanivkoval
152
32
Hi mate.
Can you give me the program installation source ?
I want to try and setup one virtual machine with Windows 10 and another with Windows 7 to test what will work and find a solution for you :)
yanivkoval
152
32
Or you can do it by yourself as DAN FR suggested...
connahiatt48
41
I'm installing the mpps software from a disc supplied with a mpps v16 tool.
yanivkoval
152
32
Ok I will try to download it from the internet :)
Meanwhile try setting the compatibility to windows xp...
connahiatt48
41
I'm going through all of the compatability modes and none are working so far.
I'm looking into virtual box as dan mentioned but can't seem to find a download?
