Decat mot pass
Legojon
I only wanted a remap
5,284
2,714
On the bright side, if it's due during lockdown, it's being extended by 6 months.
bruceR
2,540
616
Monifieth, Dundee
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,199
1,038
Kent
I really want to stay decatted but I just know it's going to cause me grief when it comes to MOT time.
Bruce, that's not for a mk1 LCR though is it?
Thai-wronghorse
Dec 3, 2015
2,199
1,038
Kent
Ah that's cheating, dervs are much easier to swing past the MOT when it comes to cats.
Reactions: bruceR
Sharpy
Oct 2, 2018
957
486
Friendly MOT tester or get a can that can be added and removed. I am intending to get one that clamps in, I can then remove it and add it back in as I wish.
Reactions: Legojon
Rich.T
1,609
932
Would swapping from cat to decat (or vice versa) cause the eml to stay on?
Tempted to fit dummy cats to mine.
Stage 1 remap 18T bam engine.
Rich
Thai-wronghorse
Dec 3, 2015
2,199
1,038
Kent
Rich
Yes, it'll need mapping out. I know you can get lambda sensor probe extensions to put it further away from the exhaust gases which can help to trick the ECU into thinking its closer to its parameters but it's not guaranteed.
I have one on my decat but as I didn't map the car I have no idea if its needed or not without experimenting first.
Reactions: mty12345 and Rich.T
SlashProm
160
22
Removing the cat will give you an EML for the secondary 02 sensor which measures the efficiency of your cat. Your best bet is to create a swap out section for the mot, or just put the cat back on for an mot if you've straight swapped it for a decat downpipe like I did. Regardless of emissions if there is no cat on your car it will fail a visual inspection before it ever gets on an emissions test. So if your mot guy wont run another car for you for the test. Your going to need a cat.
Connor H
1,015
498
Essex
I fitted one of the right angle spacers and it worked a treat. It's actually still on with my sport cat now simply because it wasnt throwing a light up either way. Suppose it would be better to have the sensor in but need to extend the cable.
