2015 FR turbo bolts missing...
Oct 25, 2022
7
Hi all, new to the site so please go easy. I've just recently inherited the 3dr FR from my late mother but now having problems. Getting the EPC light on and throwing the turbo actuator fault code. Upon further investigation it would appear that the turbo is missing a couple of bolts. See pic below. any ideas as to how i can obtain new bolts or the part number so i can order some up. Thanks in advance, Greg
Oct 25, 2022
7
which engine is it? are you sure there is bolts missing there?
It’s the 1.2 tsi the only bolt there is as shown in the picture and you can pull separate the bottom of the turbo from the bolt ring that holds it at tight together 🤷🏼‍♂️
dm222
1,474
47
post a zoom out of the turbo location so I can check if I can find it on the website, although if it has problem its likely its too late and just the bolt wont fix it
Oct 25, 2022
7
I’ll get a pic when I’m home tomorrow, it only throws the EPC light on if you try to boot it through the Rev range 👍🏼
