Thanks Andy. TBH I think the ride in my wife’s MiniCooper is harder (if you hit a pothole in that your teeth nearly fall out!) This VZ1 just seems unsettled on all but the smoothest surfaces. It’s nice in all other respects and the DSG box is good…
I seem to remember that Mini’s have run flat tyres. If so, then run flats have heavily reinforced sidewalls which are presumably very stiff to stop the tyre collapsing and coming off the wheel, as the tyres are designed so they can be driven on at speeds of up to 50 mph after getting a puncture. Generally speaking, low profile run flats as fitted to a Mini Cooper won’t result in a ride quality that could be described as very comfortable (BMW’s fitted with run flats have tended to be be criticised on their ride quality).
You confirmed in the other discussion thread you started that the tyres on your
Cupra are Bridgestones. All five of the VW’s I’ve owned came from the factory fitted with low profile Bridgestone tyres, and when I’ve had new tyres fitted - either by choice or out of necessity - I switched to an alternative brand (Goodyear, Continental or Michelin) and there’s been an improvement in ride quality over the Bridgestones. Historically, Bridgestone have tended to use quite a hard compound for their performance tyres, and when they’re low profile and are rated ‘XL’ (extra load = reinforced sidewalls) as yours are - see picture below from the other discussion thread - the ride will be firm to bordering on very firm.
It’s a shame we don’t get to choose which brand of tyres are fitted when buying a new car……..
