they only do the "smaller" type up to 30 Amp , and the "bigger" ones start at 40 and go up , its just a way of identifying that it is a larger capacity fuseHello everyone,
Would anyone know what type of fuse is the orange one? Is the same size more or less than the standard fuse (green) but thicker.
Sorry I´m a bit confused by your reply.they only do the "smaller" type up to 30 Amp , and the "bigger" ones start at 40 and go up , its just a way of identifying that it is a larger capacity fuse
A Maxi fuse is bigger than a standard fuse !Sorry I´m a bit confused by your reply.
Is it a "small" maxi fuse?
There is in the fuse as well another green 30A fuse with the same shape as the orange in the photo.
I don't really understand what you are after ! Have you not looked at the PDF I linked you to?I knew that, but if I wanted to order the orange fuse in the photo how should I call it?
a Standard fuse wouldn't fit in the slot or would it? Let´s say fuse 66 (standard) below wouldn't fit were 67 is.
You have answered your own questionWhat I´m trying to say is that the orange fuse in my photos is not a standard fuse as the shape is not the same shape at all.
My original question was, what type of fuse is it then?You have answered your own question
I answered it in post 4 and 6My original question was, what type of fuse is it then?
Lets start again what is the amperage of the orange fuse ?Sorry but in your pdf there is no fuse with the same size and shape
