Hi, I have a 2007 2.0tdi stylance and the climate control heats the car up when cold the fan works through the vents etc but when I've been driving for a while I have to turn the heat right up and the air stops coming out of the vents. Even if you turn the fan up the fan just makes a noise but only a trickle of air comes out the vents
Any ideas guys and gals
Have you tried running a scan on you Air-Con or just on the whole car to see if theres any faults related to the aircon?
i had a similar issue on my old leon (exactly same model and year as yours) where the motor on the drivers side gave up and only blew hot air when it wanted to, the it shut the air duct down.. and im sitting there with outside temperature air or no air at all...
not an easy fix if its the same motor thats defect though.. theres a metal bracket running down in front of it from under the steering wheel
Try to do a scan and post result here if you find any
problem.. if you dont have access to vcds you could try to find one in your area or drive down to a Seat
shop or other and make them do a sweep of the car and ask them to give you the out put, some dealers do it fairly cheap or with no charge at all, takes 5 min to run a scan
