electrical problem on 1.8 20v
ROd
10
Hei !
it shows up after a little drive, i get a snap in speaker , abs and tcs light comes on and central display , speedo and tach and headlights are dimming and getting bright in a frequency.
WeeC
240
Glasgow
Not quite sure I follow what your problem is but I've had two faults which caused the battery to drain and the abs and tcs lights to come on, lights to dim and then the car eventually died - 1) a faulty alternator and 2) the fuses on top of the battery all blowing/melting. I think the latter is a common fault and the fuse box type thing that sits on top of the battery needs replaced. Or is it possible your speakers are shorting somewhere?
ROd
10
I found out that it came from fuel pump relay, there was a bad gound and relay it self was faulty
Big thanks for your reply enyway
