Ibiza cupra not starting and dash lights go crazy
adamkirk160
8
Hi I need a hand
The dashbored goes mad doesn't let me start the car. The battery went flat and I replaced it checked the earth under the battery it's fine.
Any help would be greatly appreciated.
AvoK95
14
Lebanon
Check your starter relay. There are a few relays ontop of the fuse box below the dash. I think it's relay 409 (Not very sure though)
If your dash turns normally, it can be from that. If it doesn't you might have a problem with the keyhole. It's a common VW problem for this platform. You need to take the steering wheel out and replace it. There is a metal piece and an electronic piece behind it. This is also what turns off your radio when you take your key out.
