Electric wing mirror swap
Zardoz
525
214
North West
My drivers side electric mirror won't adjust after taking a few knocks. They're the older 'squarer' type and was wondering if it's possible to do a straight replacement with the newer 'teardrop' shaped ones. Would the triangular piece of plastic need swapping too on the door? Ta.
Thinking I might as well get a set of the newer ones if I'm changing it any way.
spudboy6
722
114
Swindon
There a straight swap , the triangular plastic piece is part of the mirror so no drama will be on the new ones
Also why not fit powerfolding ones ?
You will need the two mirrors , two window motors from the donor car with power gold mirrors and the switch that’s all ,
You’ve got the door card of to swap the mirror so may as well have some powerfold ones :)
Zardoz
525
214
North West
Thanks Spudboy. Yeah, that's a good idea, I'd seen a few sets of folders on eBay.
Think this will be my next project once she's through her MOT.
chriswales6
294
47
If you had a set of rectangle mirrors I’d be tempted to do a straight swap for my tear drop ones.
They look better but are a right pain to use. Because of the shape I have them tilted up to see behind me but then I can’t see where the rear wheels are when I reverse.
Zardoz
525
214
North West
That's a great offer Chris, but my drivers side mirror mechanism is goosed so would be no good to you anyway.
spudboy6
722
114
Swindon
I’ve just remembered I’ve got a pair in my garage , not powerfolding but are electric and fully working
Completely forgot I’ve still got them from when I fitted my powerfolding ones
I’ll put a pic up in here when I get home tonight
bruceR
2,540
616
Monifieth, Dundee
Hi all, is it just a straight swap or will you have to check your CCM (convenience module) to see if compatible??
spudboy6
722
114
Swindon
All straight swap
But if wanting powerfold mirrors you need switch and window motors too but all plug and play
spudboy6
722
114
Swindon
If I stuck with the square ones I'd only be after the drivers side mate.
Here’s the mirrors
Covers poorly wrapped nardo grey but platinum grey under the wrap
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
I have a set of teardrop ones in plat grey going spare.
B5 Custom Map, TIP, FMIC, 3" Turbo Back, Bosch 550's,ARB's and more .....
Zardoz
525
214
North West
How much are you (both) wanting for the mirrors guys? Colour not an issue as probably spray the covers black (my car is dark red).
If I get through my MOT painlessly tomorrow. I should have some spare cash this payday (15 Jan).
spudboy6
722
114
Swindon
I’d post the pair to you for £25 :)
spudboy6
722
114
Swindon
You sure mate? That's superb. Can you hang on till the 15?
Yea no drama , there just sat in my garage doing nothing since I put the power folds on last month ,
Message me on here when your ready
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Go with spudboy.
Think I paid a fair bit more on eBay for mine so will need more or less same when selling.
