Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » Engine Discussion » TDi - SEAT Diesel specific topics
TDi - SEAT Diesel specific topics exclusively for SEAT diesel specific topics only.
Reply
Thread Tools Rate Thread Display Modes
Old 07-08-2017, 20:41   #1
Bubble
Newbie
Bubble has 10 points
Help and Advice please!?!
Hi everyone.
I own a 56 plate Altea Tdi FR. It has done 180,000 miles. (Original clutch!)
Anyhow, I had the cambelt changed 300 miles ago, mainly because I was going on a long trip and wanted security.
I had the whole kit put on plus oil and filter and water pump and thermostat.
20 miles into my trip and the engine banged and cut out (80mph ish).
AA turned up and saw that the cambelt had come off.
It looked at first that the tensioner pulley had failed as it was at an angle, visibly.
Got towed back and left the car at the garage which did the work and I hired a car for my holiday trip.
I got a call from the garage this morning who said that the engine is scrap.
He says the cause wasn't a pulley failure but that it was a bolt which had sheared off flush with the block (I think it was on the tensioner) which allowed the belt to come adrift.
Now then, the mechanic is a lovely bloke but he has said it was bad luck on both our parts, which it was, but I'm finding that a little hard to swallow.
In my mind, if the work hadn't been done and the bolt left in place then the fault wouldn't have happened.
Surely, if the part which failed had been taken out and fastened back in, which it had, isn't there a good chance that the bolt had been weakened when removing or over tightened, allowing it to fail under tension?
Please guys, can anyone give an opinion as to where I stand on this?
As it stands now, I have a knackered engine and a garage which says it's just bad luck and inferred it isn't worth repairing.
I could really do with some sense right now.
Thank you.
Bubble is offline   Reply With Quote
Old 07-08-2017, 20:50   #2
Bubble
Newbie
Old 07-08-2017, 20:51   #3
cheshire cat
cheshire cat's Avatar
cheshire cat has 10 points
I think you need a solicitor or you could try Honest John web site advice it's .co.uk
__________________
Nic
cheshire cat is offline   Reply With Quote
Old 07-08-2017, 20:52   #4
Bubble
Newbie
Quote:
I was hoping I wouldn't have to go down that route but thanks Cheshire Cat
Old 11-08-2017, 19:17   #5
verbal_kint
Senior Member
verbal_kint has 10 points
The garage has already set his stall out pushing blame away from them.
But from your description a bolt should not just shear off without cause and that cause would rest with the last person to operate on it. The garage has responsibility.
He may be a nice guy but that should not be at your expense, they have a duty of care to ensure the work is performed correctly.
I would start to record all interactions you have with them and log your time spent dealing with the matter and costs associated with not having use of the car. This could form part of the overall claim.
Even a recon engine would set you back £2000 or more and is the car worth that?
I can highly recommend registering here and starting a thread in the motoring section, they have some very knowledgeable people to help you properly.
Consumer Action Group
Let us know how you get on.
verbal_kint is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 9
cheshire cat, CJRamze, fettweg, Ginger Si, Kpang1234, lil3520, Rusty2k, SwinDan, verbal_kint
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
