Hi Club,
The VAG history continues in the form of a Magico Black 2007 Ibiza FR...
2008 Seat Leon Cupra (Sold and then written off)
2006 Seat Ibiza Cupra (written off)
2007 Seat Leon FR (sold)
2004 Audi RS6 (sold)
2007 VW Touran
2007 Seat Ibiza FR
She is stock standard, only sporting a decat for now. Mileage when bought was 226,000km. Being 10 years old and decent miles under the tyres there are some issues on the body, wear and tear that needs some maintenance and TLC. That will be the first order of business to get her driving right before making progress into the already lengthy mod list. No one can quote me saying this one ill leave stock
Maintenance:
-Fit new gearbox mounts
-Major service
-Dent repairs
Performance:
-Software
-FMIC
-Downpipe and full exhaust
-GTB22 Turbo
-HMS CAI
-312 Brakes and Pads
-Braided Brake Lines and Uprated Fluid
Exterior:
-18" Wheels
-FK Coilovers (Purchased)
-Splitter
-Spoiler
-Diffuser
-Side Skirts
-Paint Calipers
-Xenon Headlight Retrofit (Purchased)
-Tail Light Restoration
Interior:
-New Pedals (Purchased)
-New Gear Knob and Boot (Purchased)
-Full LED lighting (Purchased)
-Boost and Oil Temp Gauges (Purchased)
-Tablet Install
-Moulded Sub Enclosure
List will grow as time goes by. The plan is to have the car prepped to take part in the Michelin Cup 2018.
Pedals upgraded
Major service done and new gearbox mount fitted
Old wornout gearknob
Removed
New boot
New knob
One of the first mods I picked up was a new set of FK Coilovers for a really good deal. Being a high mileage car the suspension was going to need an overhaul so why not upgrade
Also took the opportunity to paint the calipers red.
Rears
Fronts:
I havent set them at the lowest because I use the car as a daily, im really happy with the ride height and the comfort level. The FKs really are great quality for the price.
The drivers seat was torn on the upper bolster and the passenger seat also showing signs of wear. I contemplated reupholstering them but decided to replace them with some Recaros instead.
2013 Focus ST3 Seats before:
Drivers seat was torn due to popped airbag, so the top covers were removed to be repaired and relabeled
The fitment in the Ford is pretty strange with brackets coming off the rails in all sorts of directions. I cut them off and measured up the standard rails to make adapter plates for fitment into the VAG.
Adapter plates being cut:
Test fit in the car with passenger seat removed
Test fit on the rails (brackets had already been removed)
There was alot of back and forward to get the adapters fitting as required
Redressed the seats with the new FR logos (my aunt did the work for me and they came out perfectly)
Final fitment
#FRecaroSelfie
Being electric I had planned to hook up the power for the seat adjusters to the ciggie lighter. Turns out those wires in my car are dead (not a fuse issue as far as I could work out). Ill find an alternate power source to make the connection as currently I have a small battery under the seats for the adjustments I will also research the heaters and how to connect them correctly (winter and leather seats dont mix).
As for the comparison to the stock seats, these are just spectacular. They are comfortable but hold you firmly in place.
Gideon aka GaVeN aka 74-4 got hold of my engine cover and instrument cluster cover for some custom paintwork.
Im blown away at the quality and attention to detail. He also sprayed the engine cover for the Touran.
Cluster cover got united grey rings with gloss black fascia
Custom boost gauge and HMS vent pod fitted. Gauge is VWR spec with blue needle and white digits. Waited a while for the gauge install as I had a race pipe on order that has the boost tap fitting. With the race pipe arrival got to have the gauge connected.
Race pipe installed (with boost tap fitting)
Gauge is reading a healthy 1.4bar which is spot on for stock 96kw turbo.
Not too keen on the cluster lighting in the 6L, it definitely gives away the age of the car. As I did in our IC I did a little LED lighting upgrade but this time with a twist.
Orange on Red (Before)
Cluster stripped and covers removed. Important to note the resting position of the needles.
All orange and red LEDs changed to white and needle lighting to blue
Test in the car before reassembly
Cluster reassembled (with fresh paint work)
Cluster colour coded to match boost gauge lighting
2007 VW Touran
2007 Seat Ibiza FR
Maintenance:
-Major service
-Dent repairs
Performance:
-Software
-FMIC
-GTB22 Turbo
-HMS CAI
Exterior:
-18" Wheels
-Splitter
-Spoiler
-Diffuser
-Side Skirts
-Paint Calipers
Interior:
-Tablet Install
Pedals upgraded
Removed
New boot
New knob
Rears
Fronts:
Final fitment
#FRecaroSelfie
