Halogen DRL disabled by market
jacknagy
Egypt
I got my Toledo from Egypt and the halogen DRL is disabled by factory market and I got my vcds cable and read a lot in forums and begin to activate the cent electric adaptation channels and after I configure the channels I got a warning ( check left and right daytime light bulb ) and it is not working.
Is there is any help ?
Is it having a separate fuse and what is the fuse number ?
Can anyone the DRL is working export his adaptation channel and attached so I can know where is the mistake in configuration
camelspyyder
2 SEAT-er
Jun 26, 2014
1,305
175
Hi. You could try changing the country setting which also adjusts the lighting.
I did this using Carista to change my car from UK to Australia to enable the display modes I required.
